Deprecated function: Creation of dynamic property Drupal\Core\DrupalKernel::$_serviceId is deprecated in Drupal\Core\DependencyInjection\Container->set() (line 20 of /var/www/clients/client72/web131/web/web/core/lib/Drupal/Core/DependencyInjection/Container.php). Drupal\Core\DependencyInjection\Container->set('kernel', Object) (Line: 1191)
Drupal\Core\DrupalKernel->attachSynthetic(Object) (Line: 924)
Drupal\Core\DrupalKernel->initializeContainer() (Line: 472)
Drupal\Core\DrupalKernel->boot() (Line: 707)
Drupal\Core\DrupalKernel->handle(Object) (Line: 19)
Deprecated function: Creation of dynamic property Composer\Autoload\ClassLoader::$_serviceId is deprecated in Drupal\Core\DependencyInjection\Container->set() (line 20 of /var/www/clients/client72/web131/web/web/core/lib/Drupal/Core/DependencyInjection/Container.php). Drupal\Core\DependencyInjection\Container->set('class_loader', Object) (Line: 1194)
Deprecated function: Creation of dynamic property Drupal\Core\Http\RequestStack::$_serviceId is deprecated in Drupal\Component\DependencyInjection\Container->createService() (line 288 of /var/www/clients/client72/web131/web/web/core/lib/Drupal/Component/DependencyInjection/Container.php). Drupal\Component\DependencyInjection\Container->createService(Array, 'request_stack') (Line: 176)
Drupal\Component\DependencyInjection\Container->get('request_stack', 2) (Line: 933)
The website encountered an unexpected error. Please try again later.
Symfony\Component\HttpKernel\Exception\NotFoundHttpException: No route found for "GET /comment/10329" in Symfony\Component\HttpKernel\EventListener\RouterListener->onKernelRequest() (line 136 of /var/www/clients/client72/web131/web/vendor/symfony/http-kernel/EventListener/RouterListener.php). Drupal\Core\Routing\AccessAwareRouter->matchRequest() (Line: 112)
call_user_func() (Line: 142)
Drupal\Component\EventDispatcher\ContainerAwareEventDispatcher->dispatch() (Line: 134)
Symfony\Component\HttpKernel\HttpKernel->handleRaw() (Line: 80)
Symfony\Component\HttpKernel\HttpKernel->handle() (Line: 58)
Drupal\Core\StackMiddleware\Session->handle() (Line: 48)
Drupal\Core\StackMiddleware\KernelPreHandle->handle() (Line: 48)
Drupal\Core\StackMiddleware\ReverseProxyMiddleware->handle() (Line: 51)
Drupal\Core\StackMiddleware\NegotiationMiddleware->handle() (Line: 23)
Stack\StackedHttpKernel->handle() (Line: 708)
Drupal\Core\DrupalKernel->handle() (Line: 19)
