Drupal\Core\Database\DatabaseExceptionWrapper: SQLSTATE[42000]: Syntax error or access violation: 1142 INSERT command denied to user 'mintdev'@'localhost' for table `mintdev`.`sessions`: INSERT INTO "sessions" ("sid", "uid", "hostname", "session", "timestamp") VALUES (:db_insert_placeholder_0, :db_insert_placeholder_1, :db_insert_placeholder_2, :db_insert_placeholder_3, :db_insert_placeholder_4); Array ( [:db_insert_placeholder_0] => lwrw7yzAjsBsEJbUf72Trbu0cOJzfWbfx_sspXGCfvU [:db_insert_placeholder_1] => 0 [:db_insert_placeholder_2] => 3.21.100.34 [:db_insert_placeholder_3] => _symfony_flashes|a:1:{s:5:"error";a:123:{i:0;O:25:"Drupal\Core\Render\Markup":1:{s:9:"
